Revoke a License
Revoke a license on the switch if you need to transfer the license to a different switch.
You can permanently remove a license, which allows you to transfer the license to another switch. This should only be done when preparing to return a defective switch for a replacement switch (RMA).
The revocation parameters invalidate the feature license and generate a revocation certificate, which is the first step to releasing the license entitlement back to the license entitlement manager (LEM). The revocation certificate is contained in a file where the first part of the file name is the switch serial number and the file extension is .rvk.
System Field Descriptions
Use the data in the following table to use the System tab.
Name |
Description |
sysDescr |
Shows the system assigned name and the software version. |
sysUpTime |
Shows the elapsed time since the system last started. |
sysContact |
Configures the contact information. |
sysName |
Configures the name of this device. |
sysLocation |
Configures the physical location of this device. |
VirtualIpAddr |
Configures the virtual IP address that the CPU advertises and stores in the switch configuration file. |
VirtualNetMask |
Configures the net mask of the virtual management IP address. |
VirtualIpv6Addr |
Specifies the virtual IPv6 address. |
VirtualIpv6PrefixLength |
Specifies the length of the virtual IPv6 address prefix (in bits). |
DnsDomainName |
Configures the default domain for querying the DNS server. |
LastChange |
Displays the time since the last configuration change. |
LastVlanChange |
Displays the time since the last VLAN change. |
LastStatisticsReset |
Displays the time since the statistics counters were last reset. |
LastRunTimeConfigSave |
Displays the last run-time configuration saved. |
DefaultRuntimeConfigFileName |
Displays the default Run-time configuration file directory name. |
ConfigFileName |
Specifies the name of a new configuration file. |
ActionGroup1 |
Performs one of the following actions:
LicenseFileName |
Specifies the name of the license file in the /intflash directory. |
ActionGroup2 |
Specifies the following action: resetlstStatCounters—Resets the IST statistic counters |
ActionGroup3 |
Can be the following action:
ActionGroup4 |
Result |
Displays a message after you select Apply. |
LocatorLED |
Configures the system Locator LED on or off. The default is off. |
